K-Cars Talk about the infamous K-Cars within.
hesitates stumbles then dies
Old 09-06-2017, 11:08 PM
isaacray's Avatar
Default hesitates stumbles then dies
i have a 83 lebaron with a 2.6 liter motor. when it gets to operating temp it starts to hesitates and stumbles BAD when at idle and when I lightly apply the throttle. i have to put it in nuetral and keep the gas pedal accelerated till i have to take off. then it will stumble, buck, and even die. then ill start it right up and itll drive good. whats my first step to diagnose this problem
Old 09-08-2017, 08:42 AM
REBEL59's Avatar
Check for cracked or broken rubber vacuum lines, and then ckeck EGR vale that it is not sticking open.
Old 09-09-2017, 02:34 PM
REBEL59's Avatar
The carb on those old mitsubishi motors were a real pain also along with a relay that had a non existent replacement relay that would go bad and cause the same symptoms, even when they were NEW. I had to work on a few of those motors WAY BACK in the mid eighties, and there was little good info for them then!!!
painman
05-09-2014 10:52 AM
jmewert
04-18-2010 11:00 AM
Pt Ry
10-20-2008 03:14 PM
DaveC8656
08-08-2008 03:42 PM
DJ_Playing
04-22-2006 03:58 PM
Quick Reply: hesitates stumbles then dies
