Armrests
http://pics.ebaystatic.com/aw/pics/v...hdr1_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...hdr2_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...hdr3_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...eft1_texas.gifAnother custom made armrest from DIESEL DAWG ARMRESTS.
Most all interior truck and car door panels are not very user friendly. You have to put your arm either on the window sill which can be uncomfortable for some or the flat area on the lower portion of the door panel which is too low and you now have a SOLUTION! We have designed and manufacture these custom armrests here in Michigan. All you do is clean the flat area of the door panel as you can see with one of the pictures above with isopropyl alcohol, peel back the Velcro and you will drive more comfortably and your arm will feel great! That's it! No drilling, cutting or moving around and you can remove it at any time. We are a small company but have a huge heart and will stand behind all of our products. The vinyl and all stitching are commercial grade along with the interior foam. These are built to last from one car or truck to another. Just peel the Velcro enclosure and replace it and re-apply to your new car or truck. COLORS AVAILABLE ARE BLACK & GRAY (WE WILL BE GETTING SOME TAN COLORS SOON!) YOUR ARM WILL FALL IN A PERFECTLY PLACED ERGONOMIC POSITION TO ENHANCE YOUR DRIVING COMFORT. The dimensions are: 6 1/2 " x 3 1/4" x 2" (Length x Width x Height) NOTE: THE PICTURE ABOVE SHOWS A DODGE RAM DOOR PANEL AND A DURANGO DOOR PANEL. IF YOUR FORD OR CHEVY HAS A SIMILAR FLAT AREA ON THE BOTTOM OF THE DOOR PANEL THEN OUR ARMREST SHOULD WORK. TO CHECK THE HEIGHT FIRST, TAKE A SMALL PIECE OF A TWO BY FOUR AND LAY IT ON THE FLAT AREA OF YOUR DOOR PANEL AND SEE HOW YOUR ARM FEELS. http://pics.ebaystatic.com/aw/pics/v...ght1_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...ftr1_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...ftr2_texas.gif http://pics.ebaystatic.com/aw/pics/v...hdr1_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...hdr2_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...hdr3_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...eft1_texas.gifAnother custom made armrest from DIESEL DAWG ARMRESTS. Most all interior truck and car door panels are not very user friendly. You have to put your arm either on the window sill which can be uncomfortable for some or the flat area on the lower portion of the door panel which is too low and you now have a SOLUTION! We have designed and manufacture these custom armrests here in Michigan. All you do is clean the flat area of the door panel as you can see with one of the pictures above with isopropyl alcohol, peel back the Velcro and you will drive more comfortably and your arm will feel great! That's it! No drilling, cutting or moving around and you can remove it at any time. We are a small company but have a huge heart and will stand behind all of our products. The vinyl and all stitching are commercial grade along with the interior foam. These are built to last from one car or truck to another. Just peel the Velcro enclosure and replace it and re-apply to your new car or truck. COLORS AVAILABLE ARE BLACK & GRAY (WE WILL BE GETTING SOME TAN COLORS SOON!) YOUR ARM WILL FALL IN A PERFECTLY PLACED ERGONOMIC POSITION TO ENHANCE YOUR DRIVING COMFORT. The dimensions are: 6 1/2 " x 3 1/4" x 2" (Length x Width x Height) NOTE: THE PICTURE ABOVE SHOWS A DODGE RAM DOOR PANEL AND A DURANGO DOOR PANEL. IF YOUR FORD OR CHEVY HAS A SIMILAR FLAT AREA ON THE BOTTOM OF THE DOOR PANEL THEN OUR ARMREST SHOULD WORK. TO CHECK THE HEIGHT FIRST, TAKE A SMALL PIECE OF A TWO BY FOUR AND LAY IT ON THE FLAT AREA OF YOUR DOOR PANEL AND SEE HOW YOUR ARM FEELS. http://pics.ebaystatic.com/aw/pics/v...ght1_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...ftr1_texas.gifhttp://pics.ebaystatic.com/aw/pics/v...ftr2_texas.gif Truck Car Door Armrests | eBay |
Double hit
Sorry, I'm kinda new at this.
thanks, diesel |
