2015 Town and Country Rough Idle after Warming up
T&C 3.8L V6, vans runs fine for a while then it stalls out at red light, like a rough idle. Start then engine up, start driving and runs fine for about 5 miles (or ~10 min down the road) but the first red light I hit after that the van starts to rough idle and stalls out with no check engine light or fault codes (can repeat every time / every day).
By rough idle I mean - van revs down to idle rpm, then rpm gauge starts to jump between 300-900, then van stalls out. wait 10 sec , crank back up and it runs fine. Van had the rear main seal changed out then 3/4 was slipping so transmission was rebuilt. then i though gas so ran it to 0 and refilled plus additive, then I just changed the spark plugs and ohm'd coil packs. |
Originally Posted by ThomasD
(Post 114265)
By rough idle I mean - van revs down to idle rpm, then rpm gauge starts to jump between 300-900, then van stalls out. wait 10 sec , crank back up and it runs fine. Van had the rear main seal changed out then 3/4 was slipping so transmission was rebuilt. then i though gas so ran it to 0 and refilled plus additive, then I just changed the spark plugs and ohm'd coil packs. Good Luck! |
Since it's doing after warm up and in idle I am trying the air intake sensor and MAP sensor.
After that I will take it to my transmission guy. Thanks |
| All times are GMT -5. The time now is 03:03 AM. |
