'97 Voyager won't start!
One night, it just decided not to run. It turns over and over and over, but... It ran fine the previous day - no missing cylinders or anything. 3.0 liter V6. I've replaced the fuel pump, fuel filter, plugs, wires, cap and rotor; injectors all test to 14 ohms;old plug wires showed spark to ground. I sprayed starter fluid into the intake plenum, but nothing. No "check engine" light whatsoever. What can I try next?? Pleease!!!
Thanks so much in advance to anyone who can help me! -MVD |
RE: '97 Voyager won't start!
There may be some engine fault codes stored in the computer. These may give a clue as to what is wrong. Borrow or buy an OBD II code scanner and see if there is anything there. You may be able to borrow one at your local Autozone store. For less than the price of a tow to your dealership and their diagnostic fee, you can buy a scanner. Try eBay.
doe your van have the factory theft alarm system? mine did that after the battery went dead after i charged the battery and pulled the iod fuse in the underhood fuse block it has been fine. i have a 1997 town and country with the 3.8
