Adding Music to Uconnect Hard Drive
Hi All
I just went through a learning experience loading music to the Uconnect Hard Drive on my new Chrysler 200, So I thought I should post information to help others. Here is how I did it: 1. Use Windows Media Player (WMP) to making a playlist of the music you would like to add. 2. Insert a high capacity thumb drive in your computer. 3. Creat a folder on the thumb drive called 'My Music'. 4. With the playlist on the right side of the player, select the Synch tab. 5. The synch command should appear halfway down the right column. It will say Synch 'playlist name' to 'G:\'. or other USB Port. 6. Make the synch selection, then allow the computer to copy the files. 7. When the copying is finished, open Windows Explorer (WE). 8. The file folders on the thumb drive will be sorted by group name then album name. Since the Uconnect will not recognize folders that do not have music files, you will have to move all of the music files out of the album folders and into the group's root folder. 9. When you have moved all of the music files out of the album folders, delete the now empty album folders. 10. The thumb drive is now ready to be installed on the Uconnect. 11. Plug the thumb drive into the Uconnect. 12. Press the 'My Files' hard button. 13. Press the 'My Music' soft button. 14. Press the 'Add Music to HDD' Soft button. 15. Select the 'My Music' folder on the thumb drive. 16. Start the download. (find something else to do for a while.) 17. Enjoy your music collection on your Uconnect Hard Drive. |
