charles92154 |
02-17-2016 11:30 AM |
I really appreciate you taking the time to help me. I imagine your time is pretty valuable. the owners ended up having a friends son take to his shop. Turned out to be the fuel pump. iI have another problem with my 2000 durango..About a year ago i replaced the fuel pump,its been parked since then. i disconnect, and reconnect the battery once a month, so as to save battery, and all was fine, i'd start it up no problem, run it awhile then shut it down. last time i tried, it wont start, i bought gas and it still no start. i spray start fluid, it fires right up.this pump has about 4 miles on it. but when i turn on the key, cant hear pump. i took gas cap off still no sound. my question, which terminals can i jump to check relay, ? the fuse is the only 10 amp in there, square fuze, red clear top.can i check the fuze with a meter? again a pre-thanx for your expert advice....... oh, also, PO505, came up, when i checked for codes.But that would'nt keep it from starting, right? i can get a new one, but the question, is there a procedure to set it, once its installed? Again, thank you very much for all your help......
