Problem with '03 Town & Country
Hey. I have a '03 T&C with the 3.8L engine. I am getting a serial communications failure code P0601. The van turns over, but will not start or run. No fuel is getting to the engine, but i know the pump is good. If i leave the ignition on for a few minutes, the van will run for a few seconds then shut down. This van has the factory immobilizer installed (grey-headed key). The ground cable is pretty corroded. Could this be the problem?
If I need to change the PCM, I would prefer to go with one without key sentry. What other vehicles would have an interchangeable PCM, BCM? Thanks |
replace pcm and no u can not remove the SKIM nore can u get a used one
