Need Help identifying Chrysler door set.
I found these Chrysler doors in an attic, I'm wondering what make and model they go to and what year?
The exterior door is smooth with no ridges from top to bottom. The front of the door on top has the metal Triangle frame on the window. No solid metal frame around the window. It has an identification number on the side that says 10-1969 and a vehicle number of WH23G0A152702 I visit the wikipedia page on 1969 Chrysler New Yorker and it's almost a match, but not quite. Can any of you Antique gurus identify what make and model this car door goes to? I'll be here to answer questions if you have any. 03/13/2010. Also, any ideas on what this kind of thing might sell for would be appriciated. All the parts seem to be working and very little rust, no cracks or damage. http://machinesentience.com/antique_...left_front.jpghttp://machinesentience.com/antique_...eft_id_tag.jpghttp://machinesentience.com/antique_...eft_inside.jpghttp://machinesentience.com/antique_...eft_inside.jpghttp://machinesentience.com/antique_...ft_outside.jpghttp://machinesentience.com/antique_..._left_rear.jpghttp://machinesentience.com/antique_...ight_front.jpghttp://machinesentience.com/antique_...ght_inside.jpghttp://machinesentience.com/antique_...ht_outside.jpghttp://machinesentience.com/antique_...right_rear.jpg |
It looks like a Chrysler Newport door, but I can't be sure.
It could be any one of these: 300 Imperial Newport New Yorker Town and Country |
The inside door handle reminds me of our old 1964 Dodge, so I'd guess that the vintage should be somewhere around that time, but that gear-wheel latch makes me think it's older than that.
I think the '58 Chrysler had smooth slab sides like your doors. And HUGE tail fins. |
1 Attachment(s)
Heres my guess, a 68 Fury. Door handle and contour look similar.
I think it will be best to take that to Chrysler car showroom.They might help in finding it out.I think some clue is there on the door.It may help you in finding it out.
It is nice piece of junkyard.
I think something has been mentioned on the door.Try to find it out from there.It will surely help you out in findings.
Solution found. I found out what car it came from.
Yay I found the car:
The correct answer is: 1970 Dodge Coronet 2 door hardtop with a 318 2 bbl. oldride.com was able to help me figure it out. Check it out: http://img2.pict.com/84/ef/5d/335981...tofficial0.jpg http://img2.pict.com/7c/c7/1f/335981...tofficial0.jpg http://img2.pict.com/cb/db/1a/335981...tofficial0.jpg http://img2.pict.com/b4/e3/a2/335981...tofficial0.jpg |
