Vehicle scan report
Hi, I am looking for help from an expert on the following DTCs
ECU DTC CODE DTC DESCRIPTION STATUS PCM P1128 Closed Loop Fueling Not Achieved - Bank 1 Upstream Pending PCM P0151 O2 Sensor 2/1 Circuit Low Stored PCM P0740 TCC Out of Range Stored PCM P0132 O2 Sensor 1/1 Circuit High Stored PCM P113D O2 Sensor 1/1 Slow Response (High Frequency) Pending PCM P113E O2 Sensor 2/1 Slow Response (High Frequency) Pending WCM |
Year, model, and engine please. Mileage may also be important, please include.
What has been done so far? Did all dtc's occur suddenly or over a period of time? Only seeing pending and stored dtc's, any active dtc's? Check engine lamp on? Any drivability issues? |
Hi,
Vehicle 2011 CHRYSLER TOWN AND COUNTRY 3.6L V6 V.V.T. Odometer 350387.4 km VIN 2A4RR5DG5BR712492 at one point the car was slow to start up ca 7-10 sec, fuel consumption also high at about 15% br Urmas |
did you install bosch o2 sensors? or did the customer?
FEBI / BILSTEIN its my car over 10 years, im very calm
Suggest starting with new spark plugs, OE NGK preferred.
Any work or parts replaced recently? |
done on 03/2023 31500 miles back Iridium XP spark plugs by official dealer,
FEBI / BILSTEIN O2 sensors? why did you replace the original o2 sensors?
following DTCs
P0151 O2 Sensor 2/1 Circuit Low Stored PCM P0132 O2 Sensor 1/1 Circuit High Stored PCM P113D O2 Sensor 1/1 Slow Response (High Frequency) Pending PCM P113E O2 Sensor 2/1 Slow Response (High Frequency) Pending |
Have the O2 sensors been replaced?
Still not seeing any active codes, only pending and stored. Is the check engine lamp on? |
| All times are GMT -5. The time now is 04:17 AM. |
