Thermostat
Where is the thermostat located in a 99 Chrysler LHS? Is it hard to change out?
RE: Thermostat
here this will helhttps://w05.dealerconnect.chrysler.c...S/80add412.gifp .on a 2.7 its under here under alt.let me know moe!!
RE: Thermostat
heres the location on the 3.5 both are located on the left side of engine, son of a gun to get out.whats the problem havent changed to many stats on lhs carshttps://w05.dealerconnect.chrysler.c...S/80b1b458.gif
RE: Thermostat
Can you be more specfic?
RE: Thermostat
sure look on drivers side of engine.follow your radiator hose it will go under your brackets that hold alt..might be easier seen from under car.moe
RE: Thermostat
What would that cost to take it to a shop to get it replaced?
RE: Thermostat
its really up to your shops labor rate.stat is about $35,labor is abour 2 to 3 hours.like i said hard to get to. are you sure you need a stat??whats you problem?,moe
