lilpengwen |
09-07-2009 11:20 PM |
1998 concorde does not run..
1998 concorde with transplanted 3.5 Ho out of a 300m, I think a 99 model.. Car utilizez electronice from concorde.. Car has 35,000 miles or more since swap.. Car ran just fine, shut it off, went inside, next day went out, it rolls over but does not run.. I am getting current to crank and cam sensor, if I manually fire each coil _ I used a test spark plug grounded to acc compressor housing, they fire.. I was told it was not the timing belt by a guy who charged me 30 buck to stand in my driveay and look at it.. Over the last 2 years that car has developed a guage problem, the tack, temp, and speedo, work intermittently.. at forst they worked more often, then as time progressed, less often, but car always ran fine.. So, I cant use codes to diagnose my issue, I have replaced the BCM and guage cluster over the last couple year, as I was told they were the cause of guages not working, so if you could not use codes what would you do. I checked fuses and relays both under hood and at end of dash, everything is good.. when I checked the relay under hood, it would flash 12 or close volts as ignition wwas turned on, but it di not remain, I am at a loss,
