94 LeBaron Convertible Top
If the convertible top motor goes out - How do you get the top up and down? Is there a crank somewhere? Top went down now will not go back up. I do not hear the motor in the back running at all when I hit the botton.
What should I check? Thanks Russ |
RE: 94 LeBaron Convertible Top
Hello Russ,
I don't have the manual for your car, but I just bought a 95 LeBaron Convertible and I would start by checking the fuse panel. I did have a Pontiac Convertible years ago, and when that motor went, I disconnected th hydrolics and put it up and down by hand from then on. Good luck with that. Emery |
hey im new here so just putting in my 2cents most motors will give u a sign they are going out funny sounds and all it does sound like a fuse if it just stop working. I just bought a 94 Lebaron gtc so in looking for info as well. Good luck
