Chrysler LHS Power window issue
Old 01-15-2018, 09:38 AM
Matthew Eaton's Avatar
Default Chrysler LHS Power window issue
I have a 1999 Chrysler LHS, the power window3 on the passenger side is giving me issues. from the driver side control i have no control of the passenger window but can control all the other windows. on the passenger switch itself the window will go down but not up. had to reverse the poer going to the motor with paper clips to get the window to go back up. wondering if this could be a break in the wire somewhere or if it is an issue with the switch module on the drivers side. was told all the windows are powered from the drivers side control.
Old 01-16-2018, 05:31 PM
FIREM's Avatar
Check ground for the drivers side master switch. Have seen strange things related to that ground.
Old 04-22-2018, 06:22 PM
Ive tested the wiring on both the passenger side switch and driver side switch. when the switch is flipped in either direction there seems to be correct voltage in the line. the motor works fine from what i can see. Could it still be a ground issue? or could it be an issue with the BCM?
Old 05-06-2018, 01:34 PM
i found the bad wire but not sure where it is bad. it is the violet and white wire that runs from the passenger window switch to the master window switch on the drivers side. not sure if this wire runs straight to the switch or if there are points in the line where it connects.
Old 05-06-2018, 02:25 PM
REBEL59's Avatar
I would start checking for a broken wire in the door to body rubber boots. Starting with the drivers door(it gets used the most and the constant use can overflex the wires inside it and start breaking them with the age of your ride.
Old 05-07-2018, 06:26 AM
FIREM's Avatar
Diagram may help. Only connectors are at the door plugs C300 Drivers side , C302 right side.
Old 05-08-2018, 08:55 AM
So i found the issue. turns out the vt/wt wire that runs to the driver side master switch had a break in it. Put a short segment of 14 gauge wire in and the issue was fixed. thanks for the help
Resorting
03-10-2016 06:01 PM
Midee1
07-22-2012 11:20 AM
DaveyBoyLHS
11-09-2011 11:54 AM
lhsiiisds
12-08-2006 02:00 AM
lhsiiisds
10-17-2006 03:02 PM
Quick Reply: Chrysler LHS Power window issue
