Leaky rims
My Concorde and both my Sebrings developed leaky aluminum rims. I have compressed air at home so filling the tires back up isn't a problem but it is a nuisance. The guy at Belle Tire claims it's due to oxidation of the rim that can be fixed by unmounting the tire, cleaning the rim and applying a "black sealer" for $16/tire.
Has anyone had experience with this fix? Does it hold up? Has anyone heard of a DIY approach that works for this problem? |
just as he said it works it is called bead sealer
Good used tires shop Atlanta
Good used tires shop Atlanta Georgia, has the lowest prices on quality used tires and cheap new tires in the USA. You can visit our website at
www.atlantagoodusedtires.com |
Originally Posted by xfire04
(Post 33594)
what he said. no probs , i have had this done to a motorcycle before. :) |
-It works just fine. They just have to clean the oxidation from the inside lip before applying the sealer and you'll be good to go. The shop I go to uses a bench grinder with a large wire wheel on it.
L8R, Matt |
You can buy the bead sealer and do it yourself. I got a can at Advance Autoparts for less than $9.
If you are going to a shop ask how much more for them to rebalance your tires while they are at it. |
