Wheels and Tires Talk about rims and tires
Pacifica 19's fit on 2010 T&C?
Old May 15, 2013 | 04:26 PM
Westfalia's Avatar
Default Pacifica 19's fit on 2010 T&C?
We have a 2010 T&C Bruan conversion ramp side van that is currently running the factory 16" chrome (ugly)rims. Here is a video of the type of van.
The problem we are having is with ground clearance. Since the entire floor is lowered for wheelchair head room clearance, the van actually sits much closer to the ground than a non adapted van. As a result, driveways and speed bumps are a problem. I would like to do a +1 or +2 conversion for the rims to effectively raise the van relative to the ground. I found that Pacifica 19s look ok and might fit.
My question is, does anyone know if the bolt circle is the same and if the offset is close on the 19" Pacifica rims? Here is a link to the current wheel Factory OEM Wheels | 2010 CHRYSLER TOWN & COUNTRY Rims | A-02333U86
Here is the wheel I'm thinking of going to. It's a 19". Would NOT do chrome on this wheel.
Factory OEM Wheels | 2008 CHRYSLER PACIFICA Rims | A-02258U86
Does anyone have other suggestions for rims that would be in the 18" to 20" range with the proper bolt circle and offset? Thanks.
Meniil
Nov 30, 2014 10:00 AM
2010vert
Dec 19, 2013 01:05 PM
aldoronsanchez
Nov 5, 2010 07:19 AM
vtraudt
Oct 11, 2008 09:24 AM
SARG
Mar 26, 2008 09:47 AM
