95 Concord no start
Old Feb 6, 2007 | 01:34 PM
chuckles314's Avatar
Default 95 Concord no start
Hello,
I have a 95 Concord 3.3L 90k miles that will not start.When it is cranking the low oil pressure light comes on, and stays on, while ignition is on.
I have replaced\checked the following:
Crank sensor: new
Cam sensor: new
Spark Plugs: new
Spark Plug wires: new
Coil pack: new
PCM: different one from junkyard: no change
Getting spark: yes
Fuel pressure: checked at around 50 psi
Tried starting while in neutral: no change
Battery charged: yes
MAP sensor: disconnected no change
ASD: not checked yet
O2: not checked yet
Coil pack: Getting 12V at B+
Codes: 12 (because battery was disconnected) and 55 (end of codes)
Oil pressure sending unit: Plan to change.
Fuel filter: Plan to change
Oil and oil filter: Plan to change
When I pulled the plugs after trying to start it, they are wet with fuel, probably because it is cold out 40F and it is a rich mixture at start up.
Any ideas would be very helpful.
Chuck (a newbie)
Old Feb 12, 2007 | 11:07 PM
Default RE: 95 Concord no start
need to have some one that knows what they are doing look at the sensors and adaptive numbers.
mikedollar
Nov 27, 2009 11:45 AM
mikedollar
Sep 23, 2009 10:52 AM
zzr7ky
Mar 27, 2009 10:20 PM
stberman
Jul 4, 2005 12:04 AM
cloudrunner
Jun 23, 2005 10:23 PM
