02 sebring vert Front LCA issues
Old 11-21-2016, 08:20 AM
Ifixjetz1's Avatar
Default 02 sebring vert Front LCA issues
On my 2002 Sebring Vert I have just changed my RH front LCA for the 3rd time due to a noise when I hit sharp or deep bumps. I know there was nothing loose because I had changed the rear bushing in the summer thinking this was my issue, but the noise was still present after I put everything back together. Every time I change the LCA the noise is completely gone for 4-6 months. When testing the ball joint it shows no symptoms of being bad such as play. This time I went with a Moog basic LCA instead of the Problem solver thinking it was made on a different line or factory. I did a complete front end rebuild 1.5 years ago. The Left LCA has not had any symptoms like this. Anybody heard of something like this before?
Old 11-21-2016, 08:40 AM
I had a noise that turned out to be upper ball joints. Replaced them on my '02 sedan and '01 convertible. It's a fairly easy job that does not require removal of the strut or upper arm from the car. There's a "How To" complete with pictures over on the Chrysler Sebring Convertible Club website. The upper ball joints are sealed units with no provision for lubrication and mine were shot after about 100,000 miles. The shop manual says you need to replace the entire upper arm (which requires removal and disassembly of the strut), but as noted above you can press out the ball joint and replace it without removing the control arm.
The links on the sway bar are also possible sources of noise.
Old 11-21-2016, 08:45 AM
Ifixjetz1's Avatar
Problem with this is, I have a whole new Strut assy with new Upper Control arm that is a year old and the Sway bar bushings are 2 years old in good condition.
Old 11-21-2016, 08:48 AM
Ifixjetz1's Avatar
And the Links are also about 6 months old as well
Old 11-21-2016, 09:00 AM
Spring seats? Upper and lower?
Old 11-21-2016, 09:01 AM
Ifixjetz1's Avatar
All brand new when I replaced both strut assys
Old 11-21-2016, 09:32 AM
Sub-frame attachment bolts?
Old 11-21-2016, 09:54 AM
Ifixjetz1's Avatar
Nope, all tight. Steering rack tight too. Engine mount is 1 year old
Old 11-21-2016, 08:12 PM
The wrong engine mount can result in NVH problems. If they put in a sedan mount instead of a convertible mount, you can get excessive body shake.
Old 11-22-2016, 05:23 AM
Ifixjetz1's Avatar
I dont have any issues with body shake. as my post states, why would a ball joint go bad within 4-6 months twice?
Quick Reply: 02 sebring vert Front LCA issues
