04 Sebring Convertable Top ???????
Old 06-02-2012, 05:40 PM
Connie Hamilton's Avatar
Default 04 Sebring Convertable Top ???????
having problems with the top hydrolics leaking, is there a way to disconnect the hydrolics and just make it manual top.
Old 06-03-2012, 10:03 PM
Ribguy's Avatar
If your cylinders are leaking, the damage is already done. Sure, you can make it a manual top, just unlatch and pull it back to open and pull it up to close. It is a bit awkward to close, just be careful you don't pinch yourself with the roof frame. I operated mine this way for about 6 months. I just installed new cylinders on Friday, bought them from Hydro-e-lectric for 140 each. The job isn't hard to do, once you get the back seat and interior trim panels off. Removing the seat and panels is not difficult either.
Old 08-19-2019, 06:14 PM
lcart00's Avatar
Is it a pump leak or lift?? Lifts are not so terribly hard to change out. I just found a complete working top in a salvage area. I purchased the pump, lines and cylinders intact. Likewise I have found the cylinders for 100 plus change if I need them. You can search EBAY and Amazon for others. Manual top operation may get to be a bit cumbersome. Just my opinion
Kebring04
10-17-2019 01:37 PM
fivehole1962
10-09-2018 07:04 PM
Maxfli
03-05-2014 06:27 PM
jalo215
10-17-2012 04:38 AM
combover
11-23-2008 07:19 AM
Quick Reply: 04 Sebring Convertable Top ???????
