Installing projector headlights for 300
Old 05-08-2007, 03:24 PM
dhanksridge7's Avatar
Default Installing projector headlights for 300
What do i have to do to install my new headlights? Do i have to take off the whole front end?? please help!
Old 05-08-2007, 08:58 PM
Default RE: Installing projector headlights for 300
REMOVAL - 300C AND MAGNUM
[ol][*]Disconnect and isolate the battery negative cable.[*]Open hood and remove the two upper headlamp unit mounting screws. [*]The two upper retaining screws (1) are located just in front of the upper radiator cross-member.
NOTE: It may be necessary to loosen the side of the fascia to access the lower headlamp unit retaining screw (Refer to 13 - FRAME & BUMPERS/BUMPERS/FRONT FASCIA - REMOVAL).[*]Remove the one lower headlamp unit retaining screw. [*]Disconnect the electrical connectors.[*]Separate headlamp u[/ol]
[IMG]local://upfiles/1033/E3668349CAE54815905504AAA74C0C3A.gif[/IMG]
[IMG]local://upfiles/1033/77DF9E64C084449A94EA0E4B92082399.gif[/IMG]
[IMG]local://upfiles/1033/F3A65D341B764E128FE8656E05D748D3.gif[/IMG]
[IMG]local://upfiles/1033/243CD28E656A4490BE507375621001DE.gif[/IMG]
Old 05-09-2007, 02:22 PM
where do i go to find out how to take the front end off?
Old 05-09-2007, 03:20 PM
try it with out I have done it u can lower it a bit with out taking it all off
Old 05-09-2007, 06:20 PM
im having trouble getting the bottom screw off..how could i get in there without takeing the whole thing off?
Old 05-10-2007, 08:54 AM
take off the top half and bend it down enough to get asccess
johnrobert.i
01-14-2014 02:41 AM
adlermike
02-08-2013 04:47 PM
Reinout
07-10-2012 03:37 AM
IS300M
12-04-2008 11:01 PM
hksjza80
12-05-2006 04:41 PM
Quick Reply: Installing projector headlights for 300
