Park Assist Message after repair
Old Jun 2, 2011 | 07:32 PM
Gippy42's Avatar
Default Park Assist Message after repair
Hi guys, I recently had some minor body work, when I got it back the park assist message came on the overhead console. I called the shop and they said they probably did not reconnect the module. I looked umder the aspen and there it is a hanging. I pushed the 2 clips together, thought I had them secure but the message still appears. Do I need to disconnect the battery to reset the system?
Old Jun 3, 2011 | 07:36 AM
kkreit01's Avatar
Make sure all the plugs/harnesses for each individual rear sensor are plugged in. Each sensor has it's own wire plug, and then there is 1 main one (on the driver's side). I found this out the hard way when I installed my Mopar hitch. I initially unplugged each individual harness -- only to later find out I needed to only unplug the main one. I didn't have to remove - battery in order to reset anything after the job was complete.
In your case, the shop has to fix it for you if it worked prior to them touching it.
Old Jun 4, 2011 | 08:47 AM
Gippy42's Avatar
Default ty
Thanks, the shop did ask me to bring it back in and they would connect the harness. I found the one on the drivers side unconnected thought that was the only one. Thanks for the feedback, I'll just take it in to them since there is more than one. Appreciate it!
johnbi
Jun 6, 2011 07:02 PM
akeepsake
Sep 5, 2010 07:12 AM
cobenson
Sep 29, 2009 05:44 AM
jasstakeover
Jan 11, 2008 04:40 PM
scarface766
Oct 6, 2007 12:54 AM
