06 Pacifica--A/C problems--but all new parts
Old Jul 20, 2011 | 01:29 PM
bliss143's Avatar
Default 06 Pacifica--A/C problems--but all new parts
We have had problems with our A/C for the past two years. In that two years, we have been told it was every part of the A/C unit under the hood. So we replaced all of the and it has been refilled 6 times.
The A/C spits out some cooled air but only on the passenger side (no my dual temp is not on, but sides are set to low). It blows hot air on the driver side.
We replaced one of the three vent motors--it switched which side was hot and cold.
I am a father of 4 children--we have spent thousands of dollars. Can someone please help?
Old Jul 20, 2011 | 02:09 PM
Djinn-n-Tonic's Avatar
Be prepared to spend a Thousand more......There are only two answers to Temp problems "Left to right", assuming all is functioning properly.
One is a low refrigerant issue, which means you have a leak in the system. The second, is a Broken Blend door in the HVAC box.
The latter , unfortunately, requires removal of the box from the vehicle, which I doubt you want to Tackle on your own. Ive removed probably a hundred of these boxes in the last 6 or 7 years, and I still cringe when they pull into the shop.
pacman069
Nov 16, 2019 10:58 AM
Megan O'Clair
Aug 4, 2014 09:50 AM
GermanPacifica
Apr 26, 2013 03:28 PM
3.3lxbluevan
9
Sep 30, 2008 06:35 PM
Jun 5, 2006 05:14 PM
