06 Pacifica - no power to climate control
Old 09-14-2009, 01:54 PM
lajenner's Avatar
Default 06 Pacifica - no power to climate control
There is no power on the entire climate control module or whatever it's called on the dash.
I checked the manual for fuse info - it says the appropriate fuse also controls the radio/cd module. The power is fine to that system.
If someone can guide me, I'd sure appreciate it. I could try the fuse, but that would mean a trip to the parts store and time. If it's not a fuse, then that time is wasted.
Thanks!
Laurie
Old 09-14-2009, 08:17 PM
lajenner's Avatar
more information to add to above...
While driving in the dark this evening, I found that the lighted buttons around the digital display are on when the headlights are on. But - none of them are functioning.
Also, the passenger side headlight is out. This most likely happened at the same time the climate control went out.
Old 09-22-2009, 07:58 PM
pogytime's Avatar
I have had a few gremlins in my 04 Pacifica, a problem similar to yours. The mechanic found no power to the climate control, an open wire somewhere. He ran a power wire direct to the climate control harness bypassing whatever the problem was.That problem is fixed but on to new ones now
neuschafer
12-19-2011 08:45 PM
parrottd
02-05-2009 10:30 PM
alan
11-19-2008 01:22 PM
racingmom
10-05-2008 08:29 AM
alan
02-14-2007 11:30 PM
Quick Reply: 06 Pacifica - no power to climate control
