Clunk clunk goes the front end
Old Apr 20, 2011 | 11:16 AM
BenjaminA's Avatar
Default Clunk clunk goes the front end
'04 Pacifica
So I've replaced every bushing and link in the front end (one at a time, here and there) and all is well for about 10K miles, then it repeats the cycle.
Where can I get better grade bushings so this doesn't keep happening?
Thanks!
Old Apr 21, 2011 | 07:37 PM
m_tobin's Avatar
Our 05 had a clunk - especially when turning. Diagnosed as the PTU (transfer case). About $2K. Luckily dealer covered it.
Old Apr 21, 2011 | 11:17 PM
Djinn-n-Tonic's Avatar
Go to your local dealer and order the specified bushings. There will be a plastic insert in the bushing that MUST be installed on the sway bar with the bushings...
The clamps can be a bear to tighten...so make sure you are patient, and that they are properly and evenly tightened.
Old Jan 10, 2012 | 04:14 PM
karfreek's Avatar
Originally Posted by BenjaminA
'04 Pacifica
Thanks!
Ok, so using the info provided in another thread I was able to source aftermarket polyurethane bushings made by Energy Suspension. These are not direct fit but they bolt on with the new brackets that are included with the kit.
The part number is 9.5169R. the bracket needs a slight modification, I cut one one of the bolt slots straight through to match how the factory bracket was. This makes it easier for install and to make sure the bolts are straight for the reinstall. You do not want to cross thread the nut in the engine cradle, the slots on the new bracket are right at the limit of the bolt holes. Also you will need to put something around the stabilizer bar to keep it from moving as the new bushings are narrower. I used industrial zip ties.
Any questions just post back, I am subscribed to is thread and get an email when there is a post.
The car handles like it is on rails now. no waddling going down the road or clunking.
Jay
rtp
May 25, 2024 07:40 PM
WillyGraphic
Jul 22, 2015 03:18 PM
albundy
Jun 14, 2013 08:01 AM
moparrh
Aug 16, 2011 08:51 PM
greenstein8
Oct 4, 2009 09:16 PM
