2001 sebring conv 50k "No Bus"
Old 07-20-2007, 06:04 PM
mrb04's Avatar
Default 2001 sebring conv 50k "No Bus"
2001 sebring saying no bus and will not start has died twice and have been able to restart after cycling key a bunch but this time I don't thank it is going to restart. I have a OTC scan tool and can't comunicate with engine computor but does seem to work with everything else. any Ideas besides bad pcm
Old 07-20-2007, 07:58 PM
Default RE: 2001 sebring conv 50k "No Bus"
SCI wires U said u can talk to everything else u arnt using a 99 buck scan tool are u? See if the pcm has power and ground. Unplug the pcm and see if u get teh bus back up if it does then yeah bad pcm.
Old 07-23-2007, 09:44 PM
mrb04's Avatar
OTC genisys scanner. Other problem is after a few days the battery goes dead. If you charge it goes back down after a2 or 3 days. Do you think the pcm is draining the battery. What wires shouldI check for power and ground. If I put in a salage yard pcm will the anti-theftand vin have to be programed at dealer? thanks fro the answers.
Old 07-23-2007, 11:28 PM
dont ever put junk yard computer in ne more they will mess up more then u think. If u do have a drain put an amp meter on the batt and see what kinda amps are being pulled factory max is 35ma. SO u can talk to other computers like airbag and abs and bcm right?
Old 07-24-2007, 08:26 AM
mrb04's Avatar
yes you can talk to abs and airbag also i think body control
Old 07-24-2007, 08:33 AM
ok check the sci wires that are from the Datalink connector to the pcm see if thoes commucation lines are good if so then u have a bad pcm. If u put a junk yarn PCM in it it had skim or vtss then all the other computer will know that and then on expect that to be there and u will have a no start and well u get to replace ooo 3 or 4 different computers at once.
Old 07-26-2007, 08:44 AM
mrb04's Avatar
I towed the car to chrysler to a friend that is a service advisor and said that the computers have I believe a 8/80 warrenty. The replaced the pcm just like I thought and car ran fine for about have a day 5 to 10 starts and stops. Now is doing the same thing again. This car also had a pcm put in it in march of 2006 according to dodge and the sticker on the side. What could cause the pcm to fail any ideas. thanks MIKE
Old 07-26-2007, 11:36 PM
not really do u have aftermarket stuff tied into the car some how? HUmm some times something like a cam or crank sensor will nuke the computers seen that a few times.
Sharpski
04-19-2015 03:55 PM
Oxbmad
11-19-2013 05:36 AM
dms2228
01-24-2012 02:12 PM
aifam55
01-22-2011 05:49 PM
Quick Reply: 2001 sebring conv 50k "No Bus"
