Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 08-11-2011, 01:46 PM
Default 2002 LXI 2.7L stumbles/hesitates
My wifes 2002 LXI 2.7L just had a fuel pump installed by our local mechanic because the vehicle would have a stumble or mis/hesitation only while traveling at freeway speed. The mechanic said the computer code showed maxium fuel was being required at all times and at freeway speed the weak fuel pump couldn't deliver enough fuel up to the engine and would cause a mis/hesitation. He said no other codes were shown.
Problem is the car still has the issue and we are frankly out of money and are waiting to talk to the shop owner. We have dumped a ton of money in this car since about the 100,000 mi. mark and now has 130,000mi. and is a commuter. The car has a recent tune-up including plugs and coil packs and has had regular service since new. Can anyone please help? Thanks ahead of time.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 08-13-2011, 01:46 PM
Update: We had the car at the shop again after the fuel pump install to try and find the continuing issue of stall/hesitate at freeway speed with no luck. There are no codes showing on the computers and the car now is getting worse. It will buck badly when you try and give the car throttle when the stall/hesitate happens to the point that it will almost quit running but when you let off the throttle it will regain power. The car as mentioned still is not showing any codes and we plan to try and drive the car this weekend to see if it will pop a code so they can try and fix the issue. PM. <><
Old 08-20-2011, 10:42 PM
helo735's Avatar
Throttle position sensor
Old 08-22-2011, 04:50 PM
Looks like we finally have a fix for this problem. The car finally did show a code after it died on the freeway and did restart on the third try. It showed PO106 - barometric pressure out of range, namely the MAP sensor was bad.
So the fuel filter in the fuel pump was plugging up and the pump was on its way out and was replaced but the main issue was the MAP sensor. Mechanic said this controls fuel mixtures needed for different altitudes and was intermittingly malfunctioning. The Sebring has 140,000 miles and now runs as good as when new. We'll keep our fingers crossed for now. Thanks for the reply helo735. PM. <><
Old 08-22-2011, 07:51 PM
helo735's Avatar
I know on GM cars (I know, apples/oranges) the PCM only occasionally references MAP values to determine WOT air/fuel ratio and to error check the mass airflow sensor.
Either way, it's usually the dumbest little sensors that cause the most problems, and usually don't throw codes until you're at wits end. I had a 1999 Jeep Cherokee that had serious surging and stalling issues that I chased for months. Then one day, the Check Engine light popped on and I had it scanned. Came back to the front O2 sensor. Changed that sucker out, and never had another problem.
I'm glad to read that you got it fixed.
Tags
2002, 27, 27l, accelerate, bucks, causing, chrysler, chysler, hesitates, hesitation, powered, sebring, stalling, stumbles, surging, vbulletin
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
