2001 t &c headlamp
Old Dec 14, 2011 | 05:33 PM
jfwtandc's Avatar
Default 2001 t &c headlamp
2001T&C. Left low beam Inop. Bulb is good, 12v to socket, continuity w/ground.
I'm at a loss. My wife said hi beams worked yesterday, but not today.
Swapped start relay w/ accessory relay, no luck.
Any ideas out there? Thanks.
Old Dec 14, 2011 | 06:28 PM
if u have 12v and ground it will work use the bulb from the other headlight see if it works.
Old Dec 14, 2011 | 08:27 PM
jfwtandc's Avatar
Kevin: Thanks for the quick response. I see you have been very helpful in this forum.
I took both bulbs out from each side. Both sockets have identical volts, resistance and ground. Both bulbs work on the right side. I don't understand how I can have volts and ground, but neither bulb will work on the left!
Thanks, Jim.
Old Dec 14, 2011 | 09:59 PM
Had to get the simple stuff out of the way first keep it KISS
Get the volt meter out again turn on the lights and tell me what wires have 12v and ground then turn on the high beams and tell me the same.
Old Dec 16, 2011 | 10:38 AM
jfwtandc's Avatar
Okay, Kevin:
Both sides work normally in high beam. (I earlier mis-diagnosed because I didn't have the key turned!) The left side high beam also comes on when the turn indicator is held to the high beam flash position, but the left side low beam will not ever come on when normally selected. The high beam blue light on the dash does come on, the right side works normally, and the bulb out yellow caution light comes on.
Volts and ground are identical to both left and right headlight sockets. Volts are as follows, oriented to the socket connector pin on top:
Lamp off: left = .78v, right .48v
Lamp on dim: left = .78v, right = 12v
Lamp on bright: left = 11.75v, right = .5v.
Ground from center pin: Lamp off: .2ohm, Lamp on: .2ohm
So I think the switch is working since the voltages swap sides, and I'm thinking the ground is good. The bulb is good, as I've swapped both sides.
You're a hero if you can explain this one to me!
Thanks, Jim.
Old Dec 16, 2011 | 08:36 PM
u have a IPM or a front controller issue the IPM is he fuse box itself
Old Dec 19, 2011 | 09:33 PM
jfwtandc's Avatar
Kevin: Is there anything else I can do myself, or is it time to take it in?
Thanks, Jim.
Old Dec 19, 2011 | 11:51 PM
u can replace an ipm or front controller there is nothing to program
If u get me the part number off the 2 I might have ones I will sell cheap to ya.
Old Dec 20, 2011 | 12:09 PM
jfwtandc's Avatar
OK,Kevin, how much for a fwd controller?
-Jim
Old Dec 20, 2011 | 04:30 PM
as I said i need the number off the old one to see if the one I have will even work
