Sponsored by:
Sponsored by:
Serpentine belt replacement
Old 07-28-2016, 08:37 PM
davidgossett's Avatar
Default Serpentine belt replacement
Hi all. I have a 2009 t/c 3.3 engine. I've just heard a squeal that sounds like maybe the belt. I have 127000 miles on in I've had it since 88000 and I know it's not been changed since then the belt looked great when I got it. My question is when I replace the belt should I replace the tensioner at the same time? If so how hard is it to replace it I've never replaced a tensioner before? Thanks David
Old 07-31-2016, 08:41 PM
georgef's Avatar
I don't think it is necessary to change the tensioner unless it is bad, but when I changed the serpentine belt on my 2009 Grand Caravan SXT the tensioner pulley had some play, no one had the pulley in stock so I bought the whole tensioner assembly.
Here's how I changed the belt and tensioner:
1- Turn steering wheel all the way to the right.
2- Remove the belt splash shield (two 10mm bolts and two Christmas tree fasteners)
3- Relieve tension from belt. I used a 3/8" drive in the square hole in the tensioner (opposite the pulley), you could use a 15mm wrench on the lug at the bottom of the tensioner instead if you prefer.
4- Remove the belt.
5- Remove the 16mm bolt securing the tensioner. There in not enough room between the tensioner bolt and frame for a ratchet and socket so I used a box wrench to remove the bolt. An offset box wrench might work better.
6- Remove the tensioner from below.
7- Re-Installation tensioner, belt, and splash guard.
Since there is not a diagram under the hood for the belt routing here's a diagram I made:
Old 07-31-2016, 09:51 PM
Thanks for the reply. Very helpful. Thanks David
minvi
07-16-2011 02:54 PM
Daryl Baines
11-06-2008 04:33 PM
Daryl Baines
10-22-2008 01:35 PM
robbiedog
09-04-2007 04:19 PM
donandsandra
07-07-2007 04:17 PM
Quick Reply: Serpentine belt replacement
