No Heat
Old 01-03-2015, 09:40 PM
cirrus98's Avatar
Default No Heat
So i just changed my water pump. Did the thermostat while i'm at it and cleaned out the heater core with compressed air. I had no heat prior to changing the water pump(had to, car has 278 481KMs on it and original timing belt & water pump). Can a heater core go bad and is there a way to tell its done? Other than that, I don't know what else to look for.
Old 01-04-2015, 12:19 PM
Calab's Avatar
Air in the cooling system will prevent you from getting heat. Did you bleed the air out of the system after the work you did?
Old 01-04-2015, 07:06 PM
cirrus98's Avatar
Calab, sorry for my ignorance but how does one bleed the system? That never really crossed my mind.
Old 01-04-2015, 09:31 PM
Calab's Avatar
Old 01-24-2015, 05:09 PM
cirrus98's Avatar
Calab, bleed the system. Still not heat. Next step: Heater core is done?
Old 01-24-2015, 05:23 PM
are both the hoses to the heater core as hot as the upper radiator hose when the engine is warm?
Old 01-24-2015, 05:39 PM
cirrus98's Avatar
1 is the same as the upper rad hose(hot, cannot hold on to it for long). The 2nd one is just warm.
Old 01-24-2015, 11:48 PM
clogged heater core
Old 03-01-2015, 09:05 PM
cirrus98's Avatar
clogged heater core
Flushed it, still no heat (coolant is topped up and system bleeded). Now 1 of the 2 hose is cold, and other is blazing hot? Can it be the heater core is done?
Old 03-02-2015, 11:03 PM
yep I had said this a month ago
Quick Reply: No Heat
