PACIFICA LOW BEAMS DON'T WORK. WHERE ARE THE FUSES?
Old 01-07-2008, 07:43 PM
wig6516's Avatar
Default PACIFICA LOW BEAMS DON'T WORK. WHERE ARE THE FUSES?
Hey does any one have a picture of the wiring for the headlights to the fuses.
the low beams in my pacifica do not light up though the lights do work. all other lights turn on except for the low beams. there is no current going the the low beams.
I do not know what is the problem. is it a fuse that burned out. if so where are the fuses for the low beams. how can i maKE CURRENT go to the low beams.
IF YOU KNOW HOW TO FIX THIS PROB. OR HAVE A PIC OF THE RELAY PLEASE RESPOND.
THIS HAS PUZZLED ME.
Old 01-07-2008, 09:51 PM
Default RE: PACIFICA LOW BEAMS DON'T WORK. WHERE ARE THE FUSES?
what year pac?
Old 01-08-2008, 10:57 AM
moe's Avatar
moe
moe is offline
INTEGRATED POWER MODULE (IPM)
An Integrated Power Module is located in the engine compartment near the battery. This center contains maxi fuses, mini fuses and relays. A label that identifies each component is printed on the inside of the cover.
Cavity[/b]
Maxi Fuse[/b]
Description[/b]
40 Amp Green
Anti-Lock Brake System (ABS) Pump
Spare
30 Amp Pink
Ignition Off Draw (IOD)
40 Amp Green
Body Control Module (BCM) Feed 1
40 Amp Green
Electronic Back Light (EBL)
30 Amp Pink
Front Wipers
40 Amp Green
Starter
40 Amp Green
Power Seat C/B
9
40 Amp Green
Power Sunroof
Spare
11
40 Amp Green
Headlight Washer, Power Liftgate
12
Spare
13
40 Amp Green
Radiator Fan 1
14
Spare
15
40 Amp Green
Anti-Lock Brake System (ABS) Module
40
40 Amp Green
Driver Door Node
41
40 Amp Green
Passenger Door Node
42
40 Amp Green
Front Blower
Cavity[/b]
Mini Fuse[/b]
Description[/b]
24
20 Amp Yellow
Power Outlet (Selectable)
25
15 Amp Blue
Radio, Amplifier, Navigation, Hands-Free Phone (HFM), Electronic Vehicle Information Center (EVIC), EC, SNRF, Mirror
26
20 Amp Yellow
Power Outlet
27
Spare
28
25 Amp Natural
Horn
29
20 Amp Yellow
Cluster, CHMSL, Stop Lights, Anti-Lock Brake System (ABS)
30
10 Amp Red
Ignition Switch
31
20 Amp Yellow
Hazard
34
Spare
35
Spare
36
20 Amp Yellow
Electronic Automatic Transaxle (EATX) Solenoid
37
25 Amp Natural
ASD
38
20 Amp Yellow
Fuel Pump
39
20 Amp Yellow
A/C Clutch, MTV
44
25 Amp Natural
Rear Heated Seats
45
10 Amp Red
Anti-Lock Brake System (ABS) Ignition Run
46
20 Amp Yellow
Passenger Door
47
20 Amp Yellow
Driver Door
48
15 Amp Blue
PLG, OHC, Body Control Module (BCM), Navigation, Hands-Free Phone (HFM)
49
25 Amp Natural
Amplifier
50
15 Amp Blue
HVAC, DVD, RAD, CLK, SKREEM
CAUTION: When installing the Integrated Power Module cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Integrated Power Module, and possibly result in a electrical system failure.
CAUTION: When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it indicates a problem in the circuit that must be corrected. moe!
Old 01-08-2008, 06:35 PM
Great description, any ideas for this
My wife's 300 has a mopar remote start installed by the dealer around 2 years ago, work fine till last week. It'll start just fine, and then shut off in around 5 seconds, try it again it'll do the same thing, start for 5 secconds, and shut off. Any ideas would be apprciated. also it starts just fine with the key, just this thing with the remote start, thanks.
Old 01-08-2008, 07:08 PM
moe's Avatar
moe
moe is offline
what year red? sounds like the module itself has internal failure.moe
Old 01-08-2008, 09:24 PM
I also have a 2006 Pacifica that is experiencing the same problem with the headlights. I can't find the fuse to go to the low beams. Any suggestions??
Old 01-08-2008, 09:37 PM
Its a 05 300. with the 5.7
Old 01-09-2008, 03:35 PM
moe's Avatar
moe
moe is offline
your problem with your low beams may be the bulbs themselves,or what comtrols high and low beams.which is the ballast module hers a picture.i would try bulb first.moe
Old 01-09-2008, 03:46 PM
moe's Avatar
moe
moe is offline
hey red i see any tsb on your issue.i would say have the drb plugged in when starting and see which input cuts out shutting the car off.do you have a phone charger plugged in ?moe
Old 01-16-2008, 03:19 PM
wig6516's Avatar
I still can't find the fuses. the low beam bulbs do work. i test them already.
the fuse box next to the battery shows no fuses for low beams. what can i do to fix this problem.
Quick Reply: PACIFICA LOW BEAMS DON'T WORK. WHERE ARE THE FUSES?
