02 300m egn.swap
Old Jul 12, 2012 | 09:32 AM
williamfvs's Avatar
Question 02 300m egn.swap
My 02 300m with 3.5 had lower end knock. I found a 2000 300m 3.5 with low miles. When cars were side by side i noted that computers and soom sensor connections and flywheel were not the same. So i put the 02 flywheel on 2000 egn. I also replaced cam. Crank. And others with new sensors for a 02 3.5 . The egn. Starts and runs grate. But will not turn over 2200 rpm. In or out of gear . Check egn. Lite is on. Comp. Diag. Says cam and crank sensor prob. Replaced again. Also checked connectors for 5 volt supply. Sensor ground. And sensor signal. All ok. Still have lite on and same prob. Please help
Old Jul 12, 2012 | 11:15 AM
what are the codes?
Old Jul 12, 2012 | 12:52 PM
williamfvs's Avatar
My codes are p 0016 and p 0344
Old Jul 12, 2012 | 11:48 PM
timing is off or the cam sensor tone wheel is wrong for that year engine
Old Jul 13, 2012 | 05:56 AM
williamfvs's Avatar
Smile 02 300m egn.swap
thanks i changed cam gear and it runs nice. THANKS AGAIN!!!!!
Old Jul 13, 2012 | 08:35 AM
welcome
allenw62
Dec 7, 2017 09:39 PM
barnyard
May 25, 2011 07:30 PM
gottalebaron86
Aug 26, 2008 10:08 PM
turtlerace
Aug 26, 2008 02:15 PM
andbudzi
Feb 20, 2008 04:07 PM
