1994 Concorde replacing AC compressor
Old Jan 16, 2006 | 08:04 PM
rhockley's Avatar
Default 1994 Concorde replacing AC compressor
I have a 1994 concorde in which I have just replaced the AC compressor (R134a type). How much PAG oil do I need to add to the compressor? Is there another way of evactuaing the air/moisture out of the system other than having the mechanic shop do it or buying/renting the vacuum pump & guagues?
Thanks for your replies
Old Jan 17, 2006 | 07:10 PM
ace's Avatar
ace
Default RE: 1994 Concorde replacing AC compressor
usually you put in as much as you took out but if thats not possable then 2 oz is the max you should put in it but it should say on the a/c decal as well as how much froen as well.
as far as evac hmm not sure nobody i know has been able to do it but some small shops do it pretty cheap try them before renting make sure you call around..
Old Jan 17, 2006 | 08:42 PM
concordelover04's Avatar
In my Haynes Repair Manual it says the capacity is 28 oz. Double check with a dealer, if you have a 5-star dealer, and are a true 5-star, then they should tell you over the phone. Also, if you do any of your own work on your car, a Haynes repair manual is the best thing to have. I have repaired so many things when I had my 94 by myself, it ran like the day it was new, even after I slammed into the back of someone (insurance totaled it out cause of age, but I drove it on and off the tow truck.) I now have one for my 01 concorde and my 03 sebring conv.
Inverted
Aug 7, 2010 02:43 AM
CarlofET
Apr 24, 2007 09:35 PM
logans08
Dec 14, 2006 08:18 AM
cc2006
Aug 25, 2005 01:45 AM
cc2006
Jul 8, 2005 06:41 PM
