2000 Concorde 4th Hole at Thermostat Housing
Old Jun 26, 2010 | 11:41 AM
Creekviewer's Avatar
Default 2000 Concorde 4th Hole at Thermostat Housing
What is the fourth hole on the engine block next to the bottom bolt hole of the thermostat housing? I believe I had a leak from that hole. I can blow air into it and it sounds like it is blowing into the cooling gallery.
There is no crack in the thermostat housing and the gasket was intact.
Thanks!
Warren H.
Old Jun 26, 2010 | 04:36 PM
engine size? is it leaking how many miles do u have?
Old Jun 27, 2010 | 06:53 AM
Default 2.7 Litre - Concorde
It appeared to have some coolant coming out of it. I went to the dealer yesterday and purchased the bleeder valve housing with the attached pipe that goes between the cylinder heads and connects to the heater hose on top of the transmission. The parts manager said he sells the piece all of the time for the 2.7L engines. He said the top of the box cracks. My fast leak started after I heard a pretty noticable pop or crack noise from the engine. Does the fourth hole serve as some sort of drain? I can hear the air I blow into it on top of the motor.
Thanks!
Warren
Old Jun 27, 2010 | 06:54 AM
Default 133,000 miles on the engine
My mom owned the car and changed the oil religiously. What should I do going forward about the sludge problem?
Warren
car5car
Feb 20, 2025 04:54 AM
apedosmil
Oct 28, 2013 10:10 PM
amorton1965
Nov 24, 2012 06:49 PM
bowman
Feb 23, 2010 07:01 PM
truthwillout
Apr 17, 2008 03:27 PM
