2001 Chrysler LHS
Old Aug 12, 2013 | 07:10 PM
sgerbitz's Avatar
Default 2001 Chrysler LHS
Hey guys,
I just bought this car, and the ac display is going out, and if i tap it , it comes back on.. any suggestions?
Old Aug 12, 2013 | 07:11 PM
sgerbitz's Avatar
Old Aug 12, 2013 | 09:54 PM
replace the ac control head
Old Aug 12, 2013 | 09:56 PM
sgerbitz's Avatar
Is that what the part is called?
Old Aug 13, 2013 | 05:50 PM
FIREM's Avatar
ATC Control panel. No need to buy new if you are handy. These are nototious for solder joints that fail and can easily be repaired. Or there is a guy on ebay thet sells repaired ones for decent $$
http://300mclub.org/forums/viewtopic.php?f=10&t=12363
Old Sep 9, 2013 | 10:09 AM
slamanna212's Avatar
Will this also cause all the display lights, including the odometer display to dim and flicker sometimes?
Old Sep 9, 2013 | 10:36 AM
nope separate issue
Old Sep 12, 2013 | 05:50 PM
FIREM's Avatar
That "seperate issue" is often called the "light show" common to LH cars.
Roll the "dimmer" wheel full teavel a few times and set it just below max brilliance. If it still occurs, there was a "fix" when these cars were new.
Disconnect/reconnect the wire harness at the headlight switch a few times. Finish off with a little dielectric grease on the contacts.
Recommend you do not waste any more time here at this site. If you want real help visit www.300mclub.org we welcome all espically LH cars with real help and good advice
chrysler2001
Nov 17, 2014 07:09 PM
firestorm31
Jan 8, 2013 12:15 AM
Hippoman123
Oct 21, 2012 06:54 AM
FauxGiovanni
Oct 13, 2010 07:08 PM
Marinecorps862
Jul 11, 2007 10:55 AM
