95 chysler new yorker
Hi
I just registered and have not been able to fine a way to post. So I am attempting to do so here. Problem 95 new Yorker. turn signals and hazard signals . At times they would work for a day or so. No longer work. Have changed the flasher relay and the turn sig/hazard selector switch assy. All fuses have been checked (OK) All other functions connected to the stalk control work. Checked the removed stalk switch assy and I was ok What else can be at fault.. Body control module? I have the factory manual but there seems to be no other circuits connected to the flasher circuits. Could it be a loose ground connection somewhere? Any help would be appreciated. |
first switch has the same problem
Anyone have any Ideas as to where the grounds are located? Replaced the battery because one cell would not charge up fully.
A hard knock on the battery when it was replaced caused the turn signals/flasher to operate properly for a day then they quit working. all fuses and relays check ok. No corrosion on any relay or fuse holders is present. |
