95 chysler new yorker
Old Oct 18, 2013 | 08:09 PM
95 chrysler's Avatar
Default 95 chysler new yorker
Hi
I just registered and have not been able to fine a way to post. So I am attempting to do so here.
Problem 95 new Yorker. turn signals and hazard signals . At times they would work for a day or so. No longer work.
Have changed the flasher relay and the turn sig/hazard selector switch assy.
All fuses have been checked (OK) All other functions connected to the stalk control work. Checked the removed stalk switch assy and I was ok
What else can be at fault.. Body control module? I have the factory manual but there seems to be no other circuits connected to the flasher circuits. Could it be a loose ground connection somewhere?
Any help would be appreciated.
Old Oct 18, 2013 | 08:37 PM
94lhs's Avatar
first switch has the same problem
Old Oct 29, 2013 | 12:20 AM
Anyone have any Ideas as to where the grounds are located? Replaced the battery because one cell would not charge up fully.
A hard knock on the battery when it was replaced caused the turn signals/flasher to operate properly for a day then they quit working. all fuses and relays check ok. No corrosion on any relay or fuse holders is present.
jasonu
Oct 27, 2012 11:26 PM
frankied8642
Jul 26, 2012 03:10 PM
Sinister1jp
Apr 3, 2012 08:34 PM
sebring89
Oct 29, 2008 06:14 AM
