'95 New Yorker Computer Problem?
Car starts ....but no gauges...no oil,fuel,rpm,overhead trip,A/C...etc. Where do I start looking first?
You forgot to mention The radio and Wipers Dont work Either...:):)
Common Issue....Remove the steering column shrouds, and Look at the Ignition switch...You will likely find the Fat Pink wire Charred thru the connector. |
Sorry...wrong.
Windshield wipers and radio WORKED. I got the solution from a post on another Q&A site.....
Fuse #14 a 5 amp-er that is labeled "Message Center". It must handle a lot more than that. It was blown. Changed it. Everything works, including the A/C. Thanks anyway. |
