98 concord p0700 and p0715
Old Apr 28, 2009 | 09:32 AM
emx72's Avatar
Default 98 concord p0700 and p0715
Hi,
I have a chrysler concord 1998 that had a check engine light on and car shook a little but the shaking went away and now drives fine. I scanned for codes with my code reader and it came back to p0700 and p0715(input/Turbine Speed Sensor Circuit Malfunction). I never had the ATF fluid changed (current mileage 130000). Where is the sensor located (outside/inside transmission)? Do you think a full rebuild is in order? Thanks
Old Apr 28, 2009 | 10:10 PM
outside of tranny driver side.
Old Apr 29, 2009 | 01:38 AM
AdamsLxi's Avatar
Default Check Engine Light
EMX72,
Might want to have this light "reset" either by going to Autozone (service is free), or disconnecting the battery for 5 mins and reconnecting (this resets the master computer). Chryslers are infamous for their "check engine lights" and many people indicate that the reason may be to take your car to a dealer for unnessary repairs- I don't know. If the vehicle is not giving you any problems, I would recommend this process. If the light comes back on after a couple resets, then consult a professional. My '99 Concorde has issues with the engine light and I reset it- after about 20,000 more miles it comes back on- my code was for oxygen sensor and other components. So, after awhile, I got tired of going to Autozone and began disconnecting the battery. To date, I have 185,000 miles on the Concorde and it has never been in the shop. I do not have any engine, emission issues and my miles per gallon are not affected- which is common when an oxygen sensor goes out. I Reset the light as recently as a few days ago.......again!
Use your best judgement- this has been my experience with my engine light. Don't forgo a repair that may impair the safety of your vehicle.
Old Jun 26, 2012 | 09:11 PM
DFolds91's Avatar
I just bought a 98 concorde and its throwing the same codes, po700 po715. It went into limp mode but its a strange one. seems like its stuck in 3rd gear. Do you thing replacing the speed sensor will solve these problems or is it more then that? speedometer still works.
Old Jun 27, 2012 | 12:27 AM
Replace what the codes are first then see what U have
Old Jul 22, 2012 | 03:25 PM
nelsonkn's Avatar
Take your car to AAMCO. They'll diagnose it for free. The dealership will not. The problem is either your throttle bottle or your transmission shift solenoid. The throttle body will give intermittent issues but the shift solenoid will happen more often. Basically, the car jerks and appears to be stuck in 1st or 2nd gear. If you throw the car in neutral, turn it off and turn it back on the issue will stop until you slow down enough for the car to shift down to the lower gears. I'm pretty sure it's one of the two.
If it's the shift solenoid going bad it either stays stuck open or stuck closed. I can't remember which. Good luck.
Old Jul 22, 2012 | 04:28 PM
"p0715(input/Turbine Speed Sensor Circuit Malfunction)"
this is not a shift solenoidal problem nore a throttle body issue
Old Jul 22, 2012 | 04:34 PM
nelsonkn's Avatar
Take your car to AMMCO and get a free diagnosis. I'm not an expert. I just know I had the same issue with my POS Concorde. I don't know anything better than free.
Old Aug 3, 2012 | 06:51 PM
nelsonkn's Avatar
Any updates?
randy4golf
Apr 1, 2015 06:42 AM
04pacifica
Sep 1, 2012 12:51 PM
armybonzola
Dec 15, 2009 08:51 PM
sws4420
Apr 19, 2009 10:06 PM
jwms
Jun 23, 2008 09:47 PM
