99 LHS question...
Old Apr 18, 2010 | 07:47 PM
dvaughn669's Avatar
Default 99 LHS question...
ok first of all my 3.5 has broken a valve spring. So during the tear down i get to taking off the crank pulley and no amount of prying will pull it off. Is there a trick to removing this that I dont know? Ive done several timing belts and have never had this type of problem before.
Old May 4, 2010 | 07:47 PM
tginley's Avatar
Crankshaft dampener puller kit. 3 claws that hook on the center flat sections and has a set of 3 rods that fit inside the 18 MM crankshaft bolt. No amount of pulling is going to get it off. If you pry it or attempt to you will damage the crankshaft. Any auto parts chains will lend you the kit for free.
Davidsed
14
Mar 25, 2013 08:51 PM
clhs
Mar 15, 2011 08:06 PM
2000LHS
Oct 3, 2010 02:16 PM
boosted5speed
Jul 23, 2009 10:23 PM
val197826184
Feb 15, 2008 08:53 PM
