abs/trc problem
Old Jan 5, 2011 | 02:58 AM
qqcs's Avatar
Default abs/trc problem
Hi!
I have a problem with abs/trc.
The OBDII reader shows abs/trc sensor problem.
The check lamps show there is a problem, and abs/trc doesn't work,
but when I start moving with the car immediately after turning the key,
then the check lamps switch off, and the abs/trc works.
Do I need to replace the sensor?
Regards,
qqcs
Old Jan 5, 2011 | 10:57 AM
what are the codes from the abs module?
Old Jan 6, 2011 | 09:43 AM
qqcs's Avatar
Don't know the code.
I was just told that it's a left front sensor problem.
Unfortunately not all services here can read the codes because of incompatibility.
Old Jan 6, 2011 | 07:28 PM
Djinn-n-Tonic's Avatar
Well...unfortunately ....You will need to go to a "PAY SERVICE" for a code read.
PArts stores offer free scans so they can sell more parts.......
Would you buy your meat from the plumber??? Or let the butcher fix your leaky toilet......Of course not....So why are you letting a "Salesman" fix your car?????
Just a thought...But if the lights go out when the car is "MOVING".......It is unlikely to be a sensor issue.
Old Jan 6, 2011 | 09:30 PM
how can any one tell u what sensor it was with out the codes?
Old Jan 7, 2011 | 06:06 AM
qqcs's Avatar
This is the reason I wrote the question.
I did not want to discuss the level of the services.
Old Jan 7, 2011 | 09:37 AM
qqcs's Avatar
Probably they did not think I want to know the code.
I would ask them for the code, but that service is far from me,
and the services near have compatibility problem.
Old Jan 7, 2011 | 11:51 AM
then there is nothing that can be done on our part here
Old Jan 11, 2011 | 01:20 AM
qqcs's Avatar
I've asked the question on hungarian forums as well.
And well.... I've got good answers withe the typical failure possibilities and how to check it. They are long so I don't translate them but if some wants then I can put here an automatic translation.
Old Jan 11, 2011 | 11:06 AM
shoot any one can guess to what the prob is U asked for what the prob is no one can answer that question with out the codes if u want to throw parts at it be my guest its your money I am not into the game of guessing I will give u a better idea what it would be if I had the info that U can not provide.
