ac blows cold air but only through defrost and floor
Old Aug 3, 2010 | 08:45 PM
havoc983's Avatar
Default ac blows cold air but only through defrost and floor
i am aware of the problem and its cause at least from looking around online the common cause happens to be a blend door actuator failure.
the problem that i have run into is it is a 1991 new yorker and i cant find any specs on where this part is located at in the dash. if anyone can possibly explain to me how to find this part or show/tell me where it is and how to replace it i would gladly appreciate it
Old Aug 3, 2010 | 09:58 PM
havoc983's Avatar
i did do the engine diagnostics code check trick to see if anything might be a miss under the hood but the code came back 55
the trick 5 key turns on and off to have the engine light give a Morse code of 5 quick blinks then pause and 5 quick blinks again
i am not sure exactly where to start after this i have also checked the fuses in dash none blown and the ac still blowing cold just not through the main vents only through the defrost/floor
Old Aug 25, 2010 | 12:20 PM
havoc983's Avatar
does anybody know where i can find the location of these blend door actuators in my 91 new yorker ?????
rob71
Feb 27, 2015 12:32 PM
bbatts
Apr 14, 2011 10:26 PM
CML
Jun 20, 2010 04:30 AM
dmac1951
Dec 13, 2008 09:52 PM
nellis003
Jul 24, 2008 08:31 PM
