Chrysler 300M Year 2000 Engine shuts down while the car is in motion/also at warm up
Old Apr 23, 2014 | 03:47 PM
2000_300m's Avatar
Default Chrysler 300M Year 2000 Engine shuts down while the car is in motion/also at warm up
I have been driving a Chrysler 300M (2000 model) for the past 5 years.
Since November 2013:
1) The car has been randomly shutting down while I'm driving. The stalling happens at any speed and in a sudden instant without any warning.
2) The Engine has also stalled (on numerous occasions) during initial warm up of the car with engine idling and gear in park state.
3) During stalling the Check Engine light chimes, appears for a second and then disappears.
4) When the car is in motion at speeds above 30km/hr, if the car engine stalls, then the car restarts while still moving and in gear, kinda like a jumpstart.
5) When the car is in low speed motion, the engine stalls in totality.
Car comes to a stop. In this case, I immediately shift to neutral gear, and use whatever momentum is available to pull to the side of the road.
Then I restart the car and in all cases so far, the car has started back and I have driven it without a stalling happening for at least another 20 minutes.
6) The Chrysler workshop hasn't been able to find the problem, nor have they been successful in fixing the issue. Have left the car for more than 4 weeks. Have been to the workshop 3 times since nov 2013. All computerized obd based checkups fail to reveal the trouble codes..
Have attempted many parts replacements at no positive outcome. The list of failed fixes are:
a) Changed the camshaft sensor
b) Changed the crankshaft sensor
c) Changed the timing belt
d) Flushed and changed the transmission oil and filter
e) Flushed and changed the engine oil and filter
f) Flushed and changed the coolant
g) Got the fuel pump and fuel filter cleaned (Fuel pressure test returned a
normal reading)
h) Changed the spark plugs
I) Replaced all the old relays in the power distribution fuse box with new
relays
j) Changed the coolant thermostat
k) Replaced the PCV valve
l) Cleaned the EGR valve
m) Got the throttle body cleaned
n) Got the Engine combustion chamber cleaned
0) Got the vacuum gasket between plenum and intake manifold replaced
with a new one.
p) Replaced the 2 vacuum hoses for the intake manifold.
The problem persists...The car still stalls....
Any suggestions will be most appreciated....
Old Apr 23, 2014 | 04:10 PM
FIREM's Avatar
Hate to say throw parts at it but have seen a few issues with Ignition Switches over the years that are similar to your description.
Old Apr 23, 2014 | 04:11 PM
ANy codes in the computer when it stalls?
Old Apr 24, 2014 | 01:06 AM
2000_300m's Avatar
Default obd codes
1) Tried the key on off on off on method. Only p1684 shows.
2) Chrysler workshop found no codes on each of the 3 separate occasions that my car was left with them.
3) I took the car for a computerized check to 3 other non Chrysler workshops.They couldn't find any codes too.
4) I have used a blue tooth Dongle connected to the obd port of the car along with 'torque pro' installed on my android phone. It failed to capture any codes although it was connected to the car during the occurrence of many stalling moments.
Points to consider:
- None of the obd code readers showed the p1684 code.
Only the key on off on off method done by me returned
that code.
- the obd code readers were able to erase codes although they could not detect codes. This fact was determined as I couldn't get the p1684 code after they had used their code readers with the car. Subsequent stalling moments and key on off checks showed p1684.
- I had an aftermarket remote start installed 4 years ago, used it for a year and and haven't used it after that although it is still connected in the car.
- In October 2013 I lost my original car keys and got a spare key with different programming than the original key made. This was to prevent the finder of my original key from driving away with my car although they would still be able to open the car doors with the lost key.
- I currently use this new key only and I have a bunch of other keys on the same key chain.
JaxJim
Jul 24, 2014 09:46 AM
hkggrl27
Jan 21, 2014 09:26 PM
BigHurt
Oct 16, 2012 04:55 PM
seveniron36
12
Dec 29, 2011 11:23 AM
BigHurt
Apr 6, 2007 01:19 PM
