Chrysler Concorde 2002 Oxygen Sensors
Old Jul 27, 2012 | 05:08 PM
Merovigran's Avatar
Default Chrysler Concorde 2002 Oxygen Sensors
Chrysler Concorde 2002 LXI 3.5
The problems started last year when the engine light come on. I went to a Shop and the mechanic tested and showed bad oxygen sensors.
I replaced 02 sensors and the problem continued, after that he recommended to replace the sparks plugs and the Ignition Coils lights stills on.
Two weeks ago I went to another mechanic and he said again the Oxygen Sensors went bad again.
I decided to replace (02) upstream and (02) downstream were completed on July 23, 2012 after that the engine light still on.
Today I went to a Chrysler Dealership to check the car again and guess what. The car brings the same problem: Code PO138, PO138, PO152 and PO056 and also Checked Wiring and found PCM Faulty.
Is anybody had the same situation before????
Old Jul 27, 2012 | 08:08 PM
And what brand o2 sensor did u put in?
Old Jul 28, 2012 | 09:43 AM
Merovigran's Avatar
Default bad Oxigen Sensors
Thank you for your prompt response.
I am so afraid and scared because I replaced with 04 Bosh Sensors.
Please any advise?
Old Jul 28, 2012 | 09:52 AM
scooby's Avatar
snap-on hand held scanner was telling me i had bad 02 sensors when all were replaced. i had a bad catalytic converter. this was on a 03 concorde , im not saying this is your problem , im just saying its a possibility.
Old Jul 28, 2012 | 05:03 PM
that's your prob with there u need NTK or denso bosh never work on a Chrysler car.
scooby U have a 420 code right? that's not an o2 sensor that's a converter.
Old Jul 29, 2012 | 09:35 AM
Merovigran's Avatar
Default Bad Oxygen Sensors
I will replace them right away.
What's best?? NTK or Denso ??
Also I would like to share something with you.
When the Ignition Coil # 5 (left )were replaced I note one of the screw is loose and I don't know this could be affecting all the problem.
Thank you!
I appreciate you valuable time in sharing with me your expertise.
Old Jul 29, 2012 | 09:45 AM
Merovigran's Avatar
Thank you, very much!!
I appreciate your advise and I will look into the problem.
Old Jul 29, 2012 | 03:56 PM
Denso is dealer part NTK is comparable
Old Aug 2, 2012 | 03:21 PM
scooby's Avatar
i dunno good buddy? i just went with what the tech told me. when replaced light remained on , so took it to another tech , his machine also read bad 02 sensors , and he said the scanner will put out this same code if you have bad cats. is what i was told. these were not chrysler dealership techs , so as far as there info goes , i dunno. dealership is a hour away and i didnt have the time , i have learned my lesson.
edit = cats were replaced and light has remained off?
Old Aug 3, 2012 | 08:18 AM
Merovigran's Avatar
I will replace the sensors for Denso Brand and I will keep you posted.
Edo300USA
Mar 31, 2012 10:57 PM
pagne4u
Aug 18, 2011 04:40 PM
lauman
Aug 9, 2011 09:39 PM
scawpg
Jun 16, 2009 06:23 PM
1bad300
Apr 18, 2007 03:44 AM
