Coolant for the V6 3.5l?
Old Oct 5, 2013 | 11:11 PM
QLHS's Avatar
Default Coolant for the V6 3.5l?
Hi,
I have a 99 Chrysler LHS with about 74k miles, the coolant hasn't been changed. Is it about time that I change it?
What type of coolant does it use?
Also, I recently purchased Valvoline MaxLife Coolant for another car & noticed that it says it is compatible with all makes & models. That makes me nervous but they usually have good products, what is your opinion?
Anything helpful or any thoughts would be appreciated, thank you very much.
Old Oct 5, 2013 | 11:24 PM
U want 100k life coolant remove the lower rad hose dont do anything off the radiator
Old Oct 6, 2013 | 06:23 AM
FIREM's Avatar
Use HOAT Coolant ONLY in this car. Zerex G-05 may need to look around to find it. NAPA typically stocks it and other auto parts not so much (here in NJ) Available pre diluted (recommended) or need to mix. Flush with STEAM DISTILLED WATER, 2 plugs in the block and drain on pass side of rad. Will need 2 gallons to fill.
If the timing belt/water pump have not been dont you are overdue.
http://300mclub.org/forums/viewtopic...proper+coolant
Trent
11
Jul 23, 2012 03:41 PM
neh218
64
Nov 28, 2011 03:54 PM
bailey_uk
Aug 22, 2006 11:34 PM
98Sebring
Aug 2, 2006 08:20 PM
JXI101
Jul 13, 2005 09:56 AM
