Door Window
Old Sep 20, 2008 | 01:40 PM
donnyohs's Avatar
Default Door Window
I have a 99 300M, and the window for the driver side does not go down, I'm not sure what it could be, because I opened the door panel and the motor produces heat, and it doesn't look like anything is broken. Any Suggestions?
Old Sep 20, 2008 | 07:59 PM
Al B's Avatar
Default RE: Door Window
There could be many things that it could be. The heat could be from binding, or it could be from being worked and the regulator is broken. I would remove the regulator and see if there is a problem at the motor/regulator. Also, be very careful when working with regulators, they chop fingers easily. Where ever you can use a screw driver to move stuff around inside the door. I was just working on a car this week,key was not even in the ignition, and regulator took off squishing my pick tool. Tools are easy to replace.
Old Sep 20, 2008 | 08:38 PM
Iwant2playNOW's Avatar
I had a similar problem...it ended up being the switch. You can test it by removing one of the other 3 door panels and splicing into that paticular switch...if the drivers window moves then, this will confirm it is the switch...I paid like $15 ata salvage yard for my replacement.
Good Luck!
DIY Fizzle
Dec 13, 2011 07:26 AM
01Offroad
Feb 10, 2011 05:04 PM
mishmash1
Apr 22, 2010 03:35 PM
zoron2008
Dec 4, 2009 11:41 AM
donnyohs
Feb 16, 2007 10:04 PM
