Fuse problem
Old Jul 29, 2009 | 10:29 PM
LHS MAN's Avatar
Default Fuse problem
I have a 99 LHS, 184K miles, runs great! But a fuse keeps blowing, the one that controls the overhead lights, the radio, the CD player, the door locks, truck lock, and mirrors. Everything else works fine. I guess there is a short somewhere, but anyone know where to start? Anyone else having a problem with this fuse? It's a 10 amp, located in middle of fuse block. Thanks!!
Old Jul 30, 2009 | 01:45 PM
get a wire diagram and see if there is locations to brake the system up in 2 or 3 parts then see if it still blows with which sections plugs in.
Old Jun 7, 2010 | 01:18 PM
commodore's Avatar
Default Same Problem
I have the same problem with my 2000 Cirrus. The IOD fuse that controls the Radio, inside lights, door lock keep blowing. What was your fix??
Old Jun 7, 2010 | 08:23 PM
there is not one in common U will haft to trace it down or pay some one to do it for you
Old Jun 8, 2010 | 09:58 AM
commodore's Avatar
Default 2000 Cirrus blowing IOD fuse
OK Chrysler Tech, since you worked on these units, where would you start? the wiring is all original, nothing added or remove since new. I pulled the radio out, dome light, lighter and driver side door pannel. Does the IOD circuit supply anything under the hood? Can the BCM short out and create the short? Did you ever see this? How about the cluster?? Where would you look next?
orangeblossom
Feb 27, 2019 09:36 PM
glr44
Cirrus & Breeze
Nov 30, 2013 11:33 PM
airforce1
Feb 22, 2012 04:38 AM
vpham209
Aug 20, 2011 11:48 PM
TRev
Jan 11, 2011 05:48 PM
