Hissing
Old Oct 14, 2013 | 10:26 AM
94lhs's Avatar
Default Hissing
99 lhs makes hissing noise when transmission is not in park or neutral brakes applied and in gear.
will also do it when cold or if you raise the idle then it just stops . havent found anything leaking yet . is this one problem or two???? thanks
Old Oct 17, 2013 | 06:23 AM
94lhs's Avatar
has something to do with vacuum . can hear it under the hood cant tell where its coming from no lines are broke
Old Nov 3, 2013 | 09:07 AM
94lhs's Avatar
found a couple of air leaks . a few o rings on fuel injectors and bottom bolt on throttle body was half way out . not sure what happened there gasket still looks good
Old Nov 3, 2013 | 07:52 PM
94lhs's Avatar
got car all back together runs like new. still have like a sucking noise when cold till it warms up then its gone. then if you give any gas at all then the sucking noise for a few seconds then it stops . looking for ideas
mn2007pacifica
Jun 20, 2014 09:43 PM
471Magnum
Apr 22, 2009 10:17 PM
Josho
Oct 23, 2008 10:42 PM
Scruffy
9
Jul 5, 2008 02:20 PM
acmectec2001
Jul 27, 2007 07:04 PM
