LHS Radiator Drain
Old Dec 19, 2007 | 05:00 AM
ffhuie's Avatar
Default LHS Radiator Drain
Hello, I read and applied everything my haynes manual stated to do for a radiator change prior to a flush for my 97 LHS, however no fluids came out. I removed the cover for the radiator resovoir, turned the radiator drain **** (only turned 1/4 counter clockwise turn), and removed the entire radiator hose bleeder valve/plug instead of just opening it. I do know that I didn't follow the step to remove the radiator drain plugs on both sides of the engine block 1-because I couldn't find them, 2-because I don't know what they look like, 3-because I was told that because I was doing a flush (Prestone radiator flush) I could get away with just draining what is immediate to the radiator. Does anyone know where the drain plugs are on the engine? Should there be fluids draining from what I did or did I miss a step? thanks! Brian.
Old Dec 19, 2007 | 03:41 PM
moe's Avatar
moe
Default RE: LHS Radiator Drain
hey ffhuie,heres where and what your drain plug looks like.you might have to remove it all the way out to get fluid to flow.make sure your replace the o ring before yout reinstall.moe
Old Dec 21, 2007 | 03:34 AM
ffhuie's Avatar
Thanks for the image. However, I'm not sure about how to remove the drain ****. It only turns 1/4 turn counter clockwise and I tried pulling the drain **** out, but it didn't even move. Any sugguestions?
swright227
Dec 10, 2018 05:08 PM
chrysler2001
Dec 30, 2014 11:48 PM
7Enigma
13
Nov 16, 2014 01:24 AM
VFRbeliever
Cirrus & Breeze
Dec 8, 2007 01:30 PM
slikrik99
Aug 7, 2007 12:24 PM
