Oil mess mystery!
Old Oct 9, 2009 | 01:06 PM
Dougburgy's Avatar
Default Oil mess mystery!
Hello!
I have a 2000 Concorde with about 75K miles. Every since I bought new, there has been a messy oil condition in the left hand side (drivers) engine bay. It is a splatter effect in the mid/upper/center area of that side of engine. When going up hills, under load, hard acceleration, it will begin to smoke. Oil will coat the upper wiring harness/clip, drip on header and smoke and coat sides of fuse box, coolant resevior, drip down on frame, etc. I can't for the life of me figure out where it is squirting from to coat those areas. The areas that get coated are way up on that side and there is no oil cooling lines around there, no valve cover leak, no pressure sending unit, etc. I can also add a picture (new to this) showing the areas that are getting slimed if that would help. No idea where the source of this "oil bomb" is coming from and thought somebody out there may have already solved this mystery. I have ruled out power steering leaks and brake fluid. Pretty darn sure it's the motor oil based on color, smell, etc.
Any ideas???
Thanks!
Doug
neex
Feb 14, 2015 08:39 PM
sea-one
Jul 21, 2014 10:10 PM
9cirrus8
Cirrus & Breeze
Jul 7, 2011 10:08 PM
jzakrevsky
Nov 14, 2007 08:08 AM
robbizzle
Aug 23, 2007 01:03 PM
