Overheating and leaking antifreeze
Last night I ran into a problem with a 2000 lhs. It started overheating and is leaking antifreeze/water on the front passengers side of the car. it seems to be coming from under the radiator. any ideas? (2000 lhs 3.5L)
check hoses and clamps and if u cant find anything run the engine and look for any leak when the thermostat kicks in
it leaks while the car is off. is it common for the waterpump or radiatr to fail on these cars?
i dont really know, but if the leak is isolated pretty well towards one side of the car i would check my hoses and radiator for punctures
Trigga~
I don't mean to scare you...but my 99 LHS was doing the exact same thing. It was my head gasket. For piece of mind have a pressure test done. |
The car needed oil. But I'm in the works of needing a head gasket replacement, because there's steam like smoke coming from the tail pipe even after the car has warmed up. No disrespect, but I hate chrysler/dodge. They don't use quality parts for longevity.
Originally Posted by trigga_b
(Post 26025)
BTW I have 340,000 on my 91 Caravan - how's that for LONGEVITY? :) but I DO occasionally change the oil, but not as much now as before. And if you want to check the engine - do a compression test... tells U a lot and any home mechanic can do it with a $10-20 tester that will last U a lifetime. I bought one when I was 16, still have it, still use it. :cool: |
i didn't suspect the oil because i didnt hear any ticking and i saw a leak from the radiator and there wasnt any coolant in the resevoir. but wow a head gasket replacement? i'll have to take it to my college and let them do the job for free. oh one more unrelated qiestion, when 1 turn signal bulb blow does this make the rest not work?
it shouldnt, check fuses
(Post 26093)
