Problem with 1995 Chrysler LHS...Help?
Old Mar 27, 2010 | 03:20 PM
ShadowAssault's Avatar
Unhappy Problem with 1995 Chrysler LHS...Help?
Car was working, engine fired up and all that. 2 months later i changed the stater and fuel filter, now the engine does not fire up but it cranks?. I checked the fuel pump, it works. I checked for spark, had none so I switched the ignition coil pack and still no spark. I checked the ignition coil connector that clips to the ig coil pack and it has power. The battery seems to die fast each time i crank the engine and I've been recharging the battery also.. Spark plugs were changed not the wires. Only thing i didn't check was the crank sensor and I know the ECM is ok. Timing belt was recently replaced by another owner. So I'm lost here, used to work now it doesn't.
Old Mar 27, 2010 | 03:22 PM
I changed the starter..typo
Stikman
Apr 1, 2011 09:42 AM
Stikman
Sep 13, 2009 09:11 PM
val197826184
Feb 15, 2008 08:53 PM
Sulteric
Dec 4, 2005 06:01 PM
fred
Jul 27, 2005 07:39 PM
